Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Mon Jul 18, 2016 11:42 am
dezman wrote:i am using the Audacity 2.0.5 version
Please see my previous answer:
http://forum.audacityteam.org/viewtopic ... 17#p307917.
Here is the relevant text again:
If you need to use the 2.0.5 version of Audacity, then after putting the DLL files in the Plug-ins folder, open Edit > Preferences..., choose the "Effects" section on the left, enable the box "Rescan VST effects...", OK, and restart Audacity. When you restart, you will see a dialog and a checkbox for each new effect. Make sure the checkboxes are enabled, then OK.
dezman
- Operating System: Windows 7
Post
by dezman » Sat Jul 23, 2016 10:53 pm
the problem i am having with the latest version of audacity (2.1.2.) is that i am not able to record from a karaoke website i have been using for a long time. i am able to record a karaoke track using audacity 2.0.5. but not 2.1.2. i don't know why, i have no clue.
- Quality Assurance
Post
by Gale Andrews » Sun Jul 24, 2016 12:23 pm
dezman wrote:the problem i am having with the latest version of audacity (2.1.2.) is that i am not able to record from a karaoke website i have been using for a long time. i am able to record a karaoke track using audacity 2.0.5. but not 2.1.2.
In either version you can change to Windows WASAPI host and use the (loopback) recording device for whatever device is playing the sound. See
http://manual.audacityteam.org/man/tuto ... tml#wasapi.
Of course, you should have copyright holders' permission to record from that karaoke site.
dezman
Post
by dezman » Sun Jul 24, 2016 11:29 pm
again, in the 2.0.5 version of Audacity, after i copy and paste the reverb dll file into audacity plugin folder, these reverbs do not show when i click effect. only anwida and glaceverb reverb shows. not other reverbs that i downloaded and placed their .dll file into the audacity plugin folder.
Gale Andrews on Mon Jul 25, 2016 12:40 pm, edited 1 time in total.
Reason: added quote tags
- Quality Assurance
Post
by Gale Andrews » Mon Jul 25, 2016 12:48 pm
Again, in 2.0.5, you have to use Edit > Preferences..., choose the "Effects" section on the left, enable the box "Rescan VST effects...", OK, and restart Audacity. When you restart, you will see a dialog and a checkbox for each new effect. Make sure the checkboxes are enabled, then OK. You have to do this every time you add a new effect into the "Plug-Ins" folder.
Also be aware that Audacity is a 32-bit application. So you must install only 32-bit plugins into Audacity's Plug-Ins folder, even though you have a 64-bit version of Windows.
dezman
Post
by dezman » Mon Jul 25, 2016 10:52 pm
you are right Gale, i should have downloaded the 32 bit plugins. thank you so kindly.
- Quality Assurance
Post
by Gale Andrews » Tue Jul 26, 2016 12:39 pm
I will mark this topic {SOLVED] and lock it as this has drifted away from the original subject.
If you have any more problems recording computer playback, please just start a new topic.
