Not able to record in Mono. Please Help.
Legolegacy11
Re: Not able to record in Mono. Please Help.
Post by Legolegacy11 » Wed Jun 01, 2016 5:59 pm
I don't know why, but this has made me want to get a behringer model interface/ preamp combo. I was just looking at Amazon for what they have I am seeing the UM2 for $80 a UMC204HD for the same price $80, and the UMC22 for $120. Which of those would be the most recommended if better than my current set up?
Post by kozikowski » Wed Jun 01, 2016 8:16 pm
I think the problem with the UMC204HD is it's forced stereo. Maybe.
You're going to get a microphone on one side of a stereo show. None of these are mixers.
You have to hack your way past the ad-speak. "Two Channel" in the case of the UM2 means two inputs. I don't know they ever tell you whether it's a stereo device or not. So you have to go into each one's instruction books, propose connection scenarios and see where they fall apart.
You may never get there. I have a stereo USB device that simply vanishes if you tell Audacity it's mono.
cyrano
Post by cyrano » Thu Jun 02, 2016 12:35 am
I think most 2 channel interfaces are stereo only. You can usually only select per channel on >4 channel interfaces.
Possible exceptions:
Shure Motiv MVI (130$), includes a DSP:
http://www.shure.com/americas/motiv/mvi
Alesis Core 1 (50$?)
http://www.alesis.com/products/legacy/core-1
The Alesis could be available with a discount since it is already legacy. Check your favorite store.
