I'm involved in a project that requires processing a ton of voice files. They are all the same voice, and they will all have the same effect applied. Is there a "shortcut" so that I dont have to open and apply the effect to every. Single. File? I know audacity can save a "present effect", but I'm wondering if I can just click click click and it will apply the effects to all the files at once?
Thanks
soaren
Is there a way to apply the same effect to many files?
Re: Is there a way to apply the same effect to many files?
Audacity has limited ability for "batch processing" - it's called "Chains".
See: http://manual.audacityteam.org/man/chai ... ation.html
