The time line does not move/no recording.
andrewg2019
Post by andrewg2019 » Sun May 22, 2016 6:18 am
The line that shows what time you are at does not move. I also can't record anything. Could someone help out. I included a picture so you know what my problem looks like.
Reason: placed image inline so that it fits Forum layout
Re: The time line does not move/no recording.
Post by kozikowski » Sun May 22, 2016 9:35 am
The Tascam isn't sending any data? Can you record from anything else like a built-in microphone? If you can, then there's something wrong with the Tascam.
http://manual.audacityteam.org/man/faq_ ... tml#pauses
cyrano
Post by cyrano » Sun May 22, 2016 10:18 am
Did you install the latest driver and software for Windows 10?
http://tascam.com/product/us-1200/downloads/
Post by Gale Andrews » Sun May 22, 2016 2:48 pm
Also how long is it since you did a cold boot? To do that, Windows key, click "Power", hold SHIFT and click "Shut down".
Azulmarino
Post by Azulmarino » Wed Jul 10, 2019 3:50 am
Same problem here. Recording time bar only moves when there is some audio playing, else stops. I didnt change any settings. Maybe this was caused by some Windows Update? How to fix?
DVDdoug
Forum Crew
Post by DVDdoug » Wed Jul 10, 2019 4:30 am
It's related to how WASAPI loopback works. When there is no audio stream it stops. (It's Windows, not Audacity.)
I assume you recording streaming audio? You can try one of the alternatives for [url=https://manual.audacityteam.org/man/tut ... ndows.html]recording the sound coming out of your soundcard
