XFCE 4.12
audacity(x86-64) = 2.1.1-5.1 (from opensuse repository)
Audacity 2.1.1
Audacity crashes when sound activated recording is enabled and record button is pushed.
Code: Select all
** (audacity:5660): WARNING **: Couldn't register with accessibility bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
ALSA lib pcm.c:2267:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2267:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2267:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:867:(find_matching_chmap) Found no matching channel map
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4607
Expression 'alsa_snd_pcm_hw_params_set_format( pcm, hwParams, Pa2AlsaFormat( hostFormat ) )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1786
[xcb] Unknown request in queue while dequeuing
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
audacity: xcb_io.c:165: dequeue_pending_request: Assertion `!xcb_xlib_unknown_req_in_deq' failed.
Aborted
