Audacity 2.1.2 won't open on Windows 10
Playstation3
Post by Playstation3 » Sun Apr 10, 2016 5:50 pm
This just recently started happening. It didnt happen the last time I loaded Audactiy, about a week ago. I have not made any changes to my system since then. It was working last week. What happened and how to fix it? I have tried re-installing it and restarting my computer. No help.
themickster
Re: Audacity 2.1.2 won't open on Windows 10
Post by themickster » Sun Apr 10, 2016 7:28 pm
System Restore?
Playstation3
Post by Playstation3 » Sun Apr 10, 2016 7:52 pm
Is a system restore absolutely necessary? Ive done it before, it's more of a hassle than it's worth half the time. Is there anything else to try?
It just displays the loading sign at the center of the screen and gets stuck at it.
themickster
Post by themickster » Sun Apr 10, 2016 10:11 pm
I don't know what else to say. If it were mine, I might reset Windows to fresh install and reinstall the apps one by one until I find which of them conflicts with Audacity. Extreme, I know.
Come to think of it, have you installed or updated anything since Audacity last worked? Have you tried the latest Audacity nightly build?
Post by Gale Andrews » Sun Apr 10, 2016 11:16 pm
Enable "Reset Preferences" when you reinstall Audacity, which gives you factory fresh settings. See this FAQ which has a lot of things you can try: http://manual.audacityteam.org/o/man/fa ... tml#launch.
If a bad Windows driver update has affected your audio device, you can roll back that update in Device Manger (look in the "Sound, video and game controllers" section for your sound device then right-click over the device). Then you will need to prevent that bad update being applied again - see http://wiki.audacityteam.org/wiki/Windo ... ad_updates.
Playstation3
Post by Playstation3 » Sun Apr 10, 2016 11:32 pm
Turns out that the classic windows calculator for windows 10 was conflicting with audacity. How, I dont even know.
Oh well, now have to deal with the fugly (Yes, I meant to say fugly) windows 10 calculator. Windows 10: Ten steps back.
Playstation3
Post by Playstation3 » Sun Apr 10, 2016 11:34 pm
I apologize for the double post, did not see the new reply. I already tried that, it didnt work. I have fixed my problem however. Thansk for the tip.
themickster
Post by themickster » Mon Apr 11, 2016 7:22 am
How did you find out it was the fugly calculator?
Post by Gale Andrews » Mon Apr 11, 2016 11:20 am
Playstation3 wrote:Turns out that the classic windows calculator for windows 10 was conflicting with audacity.
Do you mean this: Old Windows 7 Calculator for Windows 10 ?
If so, that does not come with Windows 10.
themickster
Post by themickster » Mon Apr 11, 2016 12:01 pm
No it doesn't but Audacity still won't open when it's installed.
