Windows 10, Audacity 2.1.2+.
Clicking to starting a voice activated recording puts a short silence at the beginning. Is it a design feature?
Added silence at the start of voice activated recording
themickster
Re: Added silence at the start of voice activated recording
How much silence?
Does it happen every time you speak; at every trigger segment? The usual complaint is the trigger leaves out the first tiny bit of sound. Does it do that, too.
themickster
Nothing like that. I click the record button and the cursor moves rightwards for a second, give or take. It stays there until there's a sound input.
It's not a problem.
It's not a problem.
I'm betting the act of starting the tool creates a disturbance which the tool thinks is Sound. And so it starts briefly.
There's probably no way around that.
themickster
No matter, as long as all tracks have the same length lead-in.
