What recording device are you choosing in Audacity's Device Toolbar?csatennis wrote:Even if I take the file and put it in my mp3 player, I get the same sound. It's not caused by Windows Media player.
Assuming you are using Stereo Mix, try Windows WASAPI loopback recording instead. That will also help keep the recording level from getting too high.
Audacity does not add effects when recording. Right-click over the Speaker icon by the system clock then choose Playback Devices to open the Playback tab of Windows Sound. Right-click over Speakers, choose Properties then look around for enhancements or advanced settings that may be adding sound effects. Also look in the Windows Control Panel to see if Realtek has a control panel where you can disable effects.
If you still prefer to use Stereo Mix, right-click over it in the Recording tab of Windows Sound, Properties, then look for any effects you can turn off.
