Recording dropouts are fixed
themickster
Post by themickster » Mon Mar 21, 2016 2:49 pm
I got crackles when recording MIDI to audio in Vista and 10 but not XP nor 7. I fixed it in 10 by bringing the screen resolution down.
Re: Recording dropouts are fixed
Post by kozikowski » Wed Mar 23, 2016 6:53 pm
So you reduced the processing load. Good trick.
themickster
Post by themickster » Wed Mar 23, 2016 8:15 pm
I came to it by chance. I reinstalled 10 for other reasons and ran it at its default resolution for my system, which is lower than my chosen 1278 x 1024.
A trick to hand onto others with the same problem?
