loud noise when recording internet radio [SOLVED]
stardust2003
Post by stardust2003 » Tue Mar 15, 2016 11:59 pm
Hi,
I used to be able to record any radio or podcast I was listening to ... or movie ...
suddenly I try to do that and get a terrible noise.... the blue audio signal fills the
panel ... its a total mess !
Im using 2.06
Reason: more precise topic title
Re: recording live radio
Post by steve » Wed Mar 16, 2016 1:39 am
stardust2003 wrote:Im using 2.06
Do you mean Audacity 2.0.6?
That's quite an old version now. the current version is 2.1.2 which is available here: http://www.audacity.audio/download/windows/
stardust2003 wrote:suddenly I try to do that and get a terrible noise.... the blue audio signal fills the
You may have turned on "Software Playthrough" by accident. Turn it off in the "Transport" menu.
stardust2003
Re: loud noise when recording internet radio [SOLVED]
Post by stardust2003 » Wed Mar 16, 2016 2:57 am
HIT the transport .... the sofware playthrough was ticked
unticked it ... bingo.... I can record audio live on line again
many thanks for this advice
