Why does RMS change for Mix and Render when only one track?
Re: Why does RMS change for Mix and Render when only one tra
Post by kozikowski » Sat Nov 11, 2017 3:25 am
As it says several times in the paper, the tools only work in Audacity 2.1.3 or later.
