kennyreid95 wrote:I use Audacity and I would use WASAPI and did not need Stereo Mix enabled with my old headset. Now with my new headset I have to use Stereo Mix, WASAPI won't work anymore, pretty weird issue to say the least. I installed Asus Realtek Driver 6.0.1.7354
Is that the correct audio driver for the machine? Is it an Asus branded computer?
kennyreid95 wrote:I record in Mono. My mic boost is at +0.0db. I plugged in green jack in headphone port to record system audio and it does not work. I had no issue with my old headset recording system audio. Now I have an issue with this new headset. Any help woukd be appreciated. Here is the new headset I bought from Amazon. If you want to buy this headset for yourselves I highly recommend them, they sound great and mic picks up sound really well.
Amazon.com: [2015 New Version] eTopxizu ET2000 3.5mm Plug Wired Gaming Headphone with Noise Canceling & Microphone for PC Games Black Blue: Computers & Accessories
Weird issue is I get an error message in Audacity "Error while opening sound device. Please check the input device settings and the project sample rate." whenever I use WASAPI on any computer with this headset. I set the playback device as headphones and recording device as headphones because my headset green jack is plugged in headphone port and red jack plugged in mic port.
As it says on
http://manual.audacityteam.org/o/man/tu ... tml#wasapi, some devices won't record WASAPI loopback in mono. Does the error go away if you change Device Toolbar to "2 (Stereo) Recording Channels"?
You can convert a stereo recording to mono using Tracks > Stereo Track to Mono.
kennyreid95 wrote:Another weird issue is the Asus Realtek audio drivers does not detect headphones when I plug headset or headphones in front headphone port on my computer. I do not see a headphones icon in playback devices nor in volume mixer when I plug in headphones. It only detects it as speakers, I still get sound from headphones but for some weird reason windows detects it as speakers
See my question above about drivers.
Usually Realtek has a control panel in the Windows Control Panel. You should have a look there. Sometimes there are settings for tying up internal and external inputs or outputs into one visible port.
