The lack of the confirmation dialog at the end of export multiple is a new bug. Thanks for reporting it.
-- Bill
FFmpeg Problems
Re: FFmpeg Problems
I'm sorry to have to keep harping on this, but in 2.2.2 on OS X 10.10.5, the progress window simply disappears when you're going to Audacity from a different window and it doesn't immediately come to the front of the screen.
Re: FFmpeg Problems
Only if you click on the progress window itself, it turns out.
Re: FFmpeg Problems
Has no one been able to reproduce it, or do you not care about Yosemite anymore, or what?
