Using 2.1.2 (release) under Vista, I discovered that two of my keyboard shortcuts from previous revs were absent. I then set them in Preferences and they showed up there until I closed Preferences. Then they didn't respond, and when I looked back in Preferences they had disappeared. I tried to set them one at a time, OK'ing out of Preferences after each one, but the first one had disappeared when I came back to set the second one. They are present in audacity.cfg, and this file has the correct time stamp. The shortcuts are Ctrl-Q (Align start to cursor) and Alt-Q (Align end to selection end). So far, these are the only ones I've found missing.
Any suggestions?
Some Keyboard shortcuts missing
- Quality Assurance
Re: Some Keyboard shortcuts missing
Thanks Dick, but as it says in other topics, those shortcuts don't work in 2.1.2 release due to a bug.
The bug has already been fixed in our source code, so if the shortcuts are of high importance for your workflow you can use the nightly builds instead.
