toolbar Devices have no input device shown
Please state:
astro_yag
Post by astro_yag » Thu Feb 18, 2016 10:13 pm
OS Mint 17.3 LMDE 'Betsy'
Audacity 2.0.6
Audio driver PulseAudio
The Toolbar 'Device' has no devices shown in list. I have selected every device shown in "Edit/Preference/Devices/". After selecting one, it isn't shown. The audio system in tray shows Input device as 'Analog input built-in audio' and can see that it works when I play a YouTube video. Has this problem occurred before, or am I the first? I hope someone can help me configure Audacity so I can record stream audio.
Thanks for your help,
Astro_Yag
Re: toolbar Devices have no input device shown
Post by kozikowski » Fri Feb 19, 2016 1:55 am
http://manual.audacityteam.org/o/man/tu ... linux.html
I'm not a Linux elf, but there is a publication on this.
Post by steve » Fri Feb 19, 2016 2:16 am
astro_yag wrote:The Toolbar 'Device' has no devices shown in list.
Are you referring to the device toolbar?
There should be exactly the same device options in there as in "Edit/Preference/Devices". In effect it is the same control in two different places. :?
