question
benbernie
question
Post by benbernie » Mon Feb 08, 2016 12:52 am
hi is there something wrong with this software?i was recording and lp when without warning the mouse turned into the zoom in maker..i hadent done anything to cause it..im on windows 10 64 bits..there was no error message it just did this out of the blue..
lenny
Re: question
Post by steve » Mon Feb 08, 2016 1:08 am
The "F" keys F1 to F6 change the tool that is being used. See: http://manual.audacityteam.org/o/man/tools_toolbar.html
benbernie
Re: question
Post by benbernie » Mon Feb 08, 2016 1:31 am
thanks
