Audacity crashes whenever I use my external mic
I have an external blue yeti mic (connects thru USB) and whenever I try to record with it, Audacity crashes after a second (you see the recording bar trying to move, freezes, and then everything crashes) . :/ I switched to the built-in mic on my laptop and everything is fine. Does anyone know how to fix this?
Re: Audacity crashes whenever I use my external mic
Are you connecting through an adapter to a Thunderbolt port?
Which OS-X? I'm typing on a Mini under 10.9.5. I use Audacity 2.1.0, even though it's not current.
Without running Audacity, do you hear sound if you plug your earbuds into the Yeti headphone connection on the bottom?
- Quality Assurance
Why is that?kozikowski wrote:I use Audacity 2.1.0, even though it's not current.
- Quality Assurance
What version of Audacity? See the pink panel at the top of the page.moosicle wrote:I have an external blue yeti mic (connects thru USB) and whenever I try to record with it, Audacity crashes after a second (you see the recording bar trying to move, freezes, and then everything crashes) . :/ I switched to the built-in mic on my laptop and everything is fine.
Have you reset the System Management Controller? See if there is something here that helps http://forum.audacityteam.org/viewtopic ... 90#p297590.
You can also post the Audacity crash report from /Applications/Utilities/Console.app.
Same reason I use Mavericks instead of Yosemite. I have the entirely unfashionable idea that the software should do what I want instead of compulsively updating to the latest version and taking my chances. I have a little thrill watching people update to beta (or even alpha) software and then complaining about bad behavior.Why is that?
"Thank you for being a Beta Tester."
Clients tend to not care about being a beta tester.
I do use Audacity 2.1.2 for support, so I'm seeing the same panels and displays as everybody else.
It's looking good I will shortly be joining the Yosemite gaggle. I'm generating work that requires a lighter and more portable machine. I checked behind the sofa seat cushions and there was more back there than I thought. Between that and the change cup from Lori (my lorry) I may be able to spring for extra memory.
Can't have too much memory.
Have you seen my keys?
The new machine will come with Yosemite.
Amen...kozikowski wrote:Same reason I use Mavericks instead of Yosemite. I have the entirely unfashionable idea that the software should do what I want instead of compulsively updating to the latest version and taking my chances. I have a little thrill watching people update to beta (or even alpha) software and then complaining about bad behavior.Why is that?
waxcylinder
Persnally I enjoy the thrill of living Audacity's bleeding alpha edgecyrano wrote:Amen...kozikowski wrote:Same reason I use Mavericks instead of Yosemite. I have the entirely unfashionable idea that the software should do what I want instead of compulsively updating to the latest version and taking my chances. I have a little thrill watching people update to beta (or even alpha) software and then complaining about bad behavior.Why is that?
On the other hand, the newest version of Audacity has fixed a bunch of problems that I'd been having: crash after a long recording session (no data lost, but some time) or after a period of inactivity when the mac had gone to sleep; and alert windows on reopening, and logs created (which I could never find) etc etc etc.
But after upgrading to the newest version, none of that!! And it wasn't until just today that I noticed that the effects tool bar allows me to import plug-ins instead of using the finder to move them into the new plug-ins folder.
Bravo! Loving it!
Bravo! Loving it!
I wonder how moosicle is doing.
