Cannot add to Audio Track
Gideon
Post by Gideon » Tue Feb 02, 2016 6:10 pm
Hi,
Im creating a podcast by speaking in front of my computer in stages, adding to the presentation every day or so, as I have the time. My problem is that, when I come back to the job and click the 'Record' button, a new track is created at the end instead of simply continuing on the original track. Also, when I try to insert something in the middle of the original track, a new track is created and both tracks play together.
Im guessing that there is a proceedure but I do not have much experience with Audacity. Can someone tell me how to do it please?
waxcylinder
Re: Cannot add to Audio Track
Post by waxcylinder » Tue Feb 02, 2016 6:19 pm
Just use the Transport > Append Record command - or its shortcut Shift + R or Shift + Record button
Post by Gale Andrews » Wed Feb 03, 2016 1:47 pm
To clarify, Append Record is only for recording at the end of the selected tracks. Audacity does not do "punch in record" in the middle of a track.
Gideon
Post by Gideon » Wed Feb 03, 2016 5:55 pm
waxcylinder wrote:Just use the Transport > Append Record command - or its shortcut Shift + R or Shift + Record button
Thanks.
Gale Andrews wrote:To clarify, Append Record is only for recording at the end of the selected tracks. Audacity does not do "punch in record" in the middle of a track.
May I suggest that, although unnecessary for music, it might be helpful in podcasting. :idea:
Post by Gale Andrews » Wed Feb 03, 2016 6:56 pm
Gideon wrote:May I suggest that, although unnecessary for music, it might be helpful in podcasting. :idea:
It's a common feature request but some of us think we should only have a "non-destructive" system where for example the original and retaken sections are stored in "layers", and that we should not do a destructive punch in that can only be undone immediately afterwards.
Which would you want?
Gideon
Post by Gideon » Wed Feb 03, 2016 11:06 pm
Gale Andrews wrote: Which would you want?
Hi Gale. Im not really experienced enough to have a strong opinion on this. Im grateful that Audacity even exists.
Cheers :)
Gideon
Post by Gale Andrews » Thu Feb 04, 2016 3:54 pm
That counts as a vote for a "destructive" method then, unless you change your mind.
With a destructive punch in for example, if you did a punch in, recorded a new track, then wanted to undo the punch in, you can't do that without undoing the new recording as well. You would have to export the new recording or copy/paste it to a new project to get out of that.
