some plugins are not enabling in 2.1.2 rc audacity
yugioh47
Post by yugioh47 » Sat Jan 30, 2016 6:48 pm
hi there, i don't get an error or anything. i've tryed to enable some plugins but they are still in new plugins by which isn't enabling. when i press ok and even enable them then press ok it's still disabled. like binaural beats with surf 2 and hard limiter. those are the 2 that are having this problem with audacity. gale would you please fix this?
Re: some plugins are not enabling in 2.1.2 rc audacity
Post by Gale Andrews » Sat Jan 30, 2016 8:43 pm
Here is 2.1.2 release http://audacityteam.org/download/windows. Use that.
Try quitting Audacity, deleting the "Users\<your user name>\AppData\Roaming\Audacity\pluginregistry.cfg" file, then restart Audacity and enable the plugins again.
