Pitch (EAC) display
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
DickN
Pitch (EAC) display
Post by DickN » Thu Jan 28, 2016 8:08 pm
Long ago and far away (since I've uninstalled all the 1.x.x's), I think I recall the 'Pitch (EAC)' selection in the TCP showing a chromatic scale of some format. Now (2.1.2) it shows frequencies. It's a feature I seldom use, but I wanted to try it for chording a song and discovered the display format change. What's the intended use of this algorithm if not identifying notes?
I tried earlier versions and found that in 2.0.3, 2.1.0 and 2.1.1 the vertical scale and the plot are all blank.
2.1.2 has scale settings Linear, Logarithmic, Mel, Bark, ERB and Period. I understand Linear, Log and Period, but what are Mel, Bark and ERB?
- DickN
Re: Pitch (EAC) display
Post by steve » Fri Jan 29, 2016 1:47 am
DickN wrote:I think I recall the 'Pitch (EAC)' selection in the TCP showing a chromatic scale of some format.
No, I don't think that was ever the case in Audacity, though it may have been an intention that was never realised.
Until very recently the EAC view did not work well at all. There has recently been a bug fix which has considerably improved the EAC display, though the vertical scale is still not particularly useful for identifying notes.
DickN wrote: I tried earlier versions and found that in 2.0.3, 2.1.0 and 2.1.1 the vertical scale and the plot are all blank.
if you look really closely, they are not quite blank, but the information that should be visible is barely visible at all. That's the bug that was fixed recently.
DickN wrote:2.1.2 has scale settings Linear, Logarithmic, Mel, Bark, ERB and Period. I understand Linear, Log and Period, but what are Mel, Bark and ERB?
Linear and logarithmic are likely to be the only scales that you need. the other scales are described on Wikipedia. They were added by the developer who fixed the above EAC bug.
Post by Gale Andrews » Fri Jan 29, 2016 5:51 pm
The Manual gives you basic explanation and the links to Wikipedia: http://manual.audacityteam.org/o/man/sp ... tml#others.
