Windows 10 taskbar VS Audacity 2.1.1
Emerogork
Post by Emerogork » Tue Jan 26, 2016 11:07 pm
I have Audacity running and choose to minimize the window. From there, although the task bar responds when I select the icon, it does not present the window again. I have to click on the desktop icon as if to open a new session and the original shows. Unfortunately, it opens as full screen. If I were to click the center icon to reduce from full screen, it hides the screen instead.
This just started happening yesterday.
Whats more, I have two WIN10 systems. This happens on only one of them....
cyrano
Re: Windows 10 taskbar VS Audacity 2.1.1
Post by cyrano » Wed Jan 27, 2016 12:33 am
And it only happens with Audacity, I presume?
Emerogork
Post by Emerogork » Wed Jan 27, 2016 2:04 am
So far, yes. Only with Audacity and only on one of two Win 10 computers.
I have performed a shutdown twice now.
Post by Gale Andrews » Wed Jan 27, 2016 4:21 pm
Emerogork wrote:I have Audacity running and choose to minimize the window. From there, although the task bar responds when I select the icon, it does not present the window again. I have to click on the desktop icon as if to open a new session and the original shows. Unfortunately, it opens as full screen.
I assume the other machine does that? I think that is a minor bug. And in any case there is a known bug that clicking the icon when Audacity is already running should open a new project window (at the same size).
Emerogork wrote:I have performed a shutdown twice now.
Try holding SHIFT and pressing the Shutdown button in the Start Menu which does a cold boot into a new kernel session.
The default shut down saves the old kernel session in the hibernation file, then uses that old session when booting up. So it probably won't solve any problems you may be trying to fix.
