Help fixing my aup file?
Please state:
Humanismradio
Post by Humanismradio » Thu Jan 21, 2016 12:59 pm
Using Audacity 2.0.5 and I am having troubles for the .. time with opening saved aup files (important interviews for broadcasting :cry: )
The file I would like to fix can be found as attachment.
I tried this:
open file
Import as audio
import as raw data
import as midi (hopeless)
And I get this message: did not recognize the file ...
If it is not a compression-file, please try to import it as a raw-data file.
When i did this:
Coded Signed 16 bit PCM
Byte order: upside down
Sample frequency: 44100
What is imported is a strange thing...I attach a screenshot to show. Please, can anybody fix it and help me to look for a bug or something? My brother has been abled to fix the other times, but I can't ask him all the time and want to know what I am or de program is doing wrong...Thanks so much!
Can
Bemoeizorg 5 jan 14 uur.aup
(39.58 KiB) Downloaded 73 times
Audacity raw dat.png (136.1 KiB) Viewed 952 times
Re: Help fixing my aup file?
Post by kozikowski » Fri Jan 22, 2016 5:04 am
AUP is not an Audacity sound file.
An Audacity Project has a AUP file which contains the instructions how Audacity is to construct the show from the contents of the _DATA folder of the same name. You must have both and they have to both be in the same place or folder for the show to open.
Where is your _DATA folder?
test-tone.aup
test-tone_data
That is a complete, self-contained project. Double click the AUP file and Audacity will automatically launch and open the show.
Post by kozikowski » Fri Jan 22, 2016 5:08 am
This is a screenshot of what your AUP looks like in a text editor. Look for the tag projname=" That's what your _DATA folder looks like.
Screen Shot 2016-01-21 at 21.06.48.png (105.37 KiB) Viewed 945 times
Post by Gale Andrews » Fri Jan 22, 2016 6:23 pm
Just to clarify, the only way to open an AUP file is File > Open... .
Post by kozikowski » Sat Jan 23, 2016 3:38 am
Maybe on your machine. On Macs double clicking opens the Project.
Post by Gale Andrews » Sat Jan 23, 2016 3:46 pm
Yes, of course that works too (as long as the file association with Audacity is set correctly) and so does right-click > Open with.
I was referring to the list of methods that Humanismradio was using.
Post by kozikowski » Sat Jan 23, 2016 6:00 pm
If you made the show and saved the project, then the _DATA folder may still be on your machine. Audacity will not search all over for it. You should use the Windows search tools to find it and then move it so that it's close to its AUP file.
If the show was shot by someone else and provided to you, the producer should have provided both the AUP file and the _DATA folder. Without the _DATA folder, you have no show.
