I Found A Way To Isolate A Section & Record It
shocked123
Operating System: Windows 7
Post by shocked123 » Wed Jan 20, 2016 12:11 pm
So I made a recording and I wanted to isolate a small section of it and make a recording of that. Here is how I found a way to do it. I very much love the feature that Audacity has created under EDIT/SELECT named "left at playback and right at playback". With it you can isolate exactly what you want to edit. I go to EDIT, SELECT and hit ALL. I then use the "right/left at playback position" to edit what I want and then I hit STOP. Then I go to FILE and I hit EXPORT SELECTED AUDIO and name the edit whatever I want and make it a second file.
Re: I Found A Way To Isolate A Section & Record It
Post by steve » Wed Jan 20, 2016 12:24 pm
Glad you've got it working.
I've just posted some additional hints in your other topic: http://forum.audacityteam.org/viewtopic ... 87#p296387
