LIve Equalizer?
Please state:
Re: LIve Equalizer?
Post by Gale Andrews » Fri Feb 26, 2016 5:12 pm
Beatnik wrote:I am using Ubuntu 14.04 and Audacity 2.1.2 Heres a screenshot what I get when I click the options.
Given you see the graphical interface, I don't understand what the exact problem is.
If you want to see a bar graph in real-time, click the "Analyzer" button in the effect.
Beatnik
Re: LIve Equalizer?
Post by Beatnik » Fri Feb 26, 2016 5:38 pm
Basic graphic eq like Audacity uses. Parametric is fine.
Re: LIve Equalizer?
Post by Gale Andrews » Sat Feb 27, 2016 2:21 pm
Beatnik wrote:Basic graphic eq like Audacity uses. Parametric is fine.
If you don't like the Calf EQ's then try something here http://linux-sound.org/plugins.html.
Beatnik
Re: LIve Equalizer?
Post by Beatnik » Sat Feb 27, 2016 11:17 pm
Thanks !
First I'm going to see what I can do with this parametric, then I'll look into those. Found an old vcr tape recording I'd like to work on.
Beatnik
Re: LIve Equalizer?
Post by Beatnik » Mon Feb 29, 2016 12:48 am
Now it doesn't work. Opens, you can adjust but hear no change.
Re: LIve Equalizer?
Post by Gale Andrews » Mon Feb 29, 2016 11:57 am
Beatnik wrote:Now it doesn't work. Opens, you can adjust but hear no change.
What effect exactly does not work? Please give the name of the effect, and the type of effect it is (click the "Manage" button in the effect, then "About").
Beatnik
Re: LIve Equalizer?
Post by Beatnik » Mon Feb 29, 2016 3:35 pm
It's strange I had messed with nomalize and after that the calf 12 band eq wouldn't work. It would slow me to make adjustments, but wouldn't change the audio. Bypass was not on. I opened the original file and all worked fine. I've found saving the eq as a preset occasionally keeps me from loosing settings if there's a crash.
Beatnik
Re: LIve Equalizer?
Post by Beatnik » Tue Mar 01, 2016 8:09 pm
I see the calf 30 band eq listed here http://manpages.ubuntu.com/manpages/wil ... alf.7.html
Does this mean I can use this in 14.04 if I figure out how to get it loaded to my computer ???
Re: LIve Equalizer?
Post by Gale Andrews » Wed Mar 02, 2016 1:53 pm
Beatnik wrote:I see the calf 30 band eq listed here http://manpages.ubuntu.com/manpages/wil ... alf.7.html
Ubuntu Wily is v15.10. You have 14.04.
It is not usually recommended to install deb packages for versions of Ubuntu other than the one you have.
If you update to 15.10 then you can definitely use that Calf package.
Beatnik
Re: LIve Equalizer?
Post by Beatnik » Wed Mar 02, 2016 7:22 pm
That would mean me updating three times hoping not to crash. lol
