Where are my lame files?
This section is now closed
Howard Brazee
Post by Howard Brazee » Fri Mar 06, 2009 2:00 am
I installed Lame for Audacity repeatedly. If I don't default, I see that it installs in a LIB/AUDACITY file. But I can't find it. I do finder searches for files modified today. Somehow I need to tell Audacity where they are, but I can't find them!
How do I find them?
Re: Where are my lame files?
Post by kozikowski » Fri Mar 06, 2009 6:08 am
Let's try...
User > koz > Library > Application Support > audacity
Yours won't say "koz."
The file you're actually looking for is libmp3lame.dylib
All that's assuming an Intel Mac.
Apple > About This Mac > Processor.
Do you have an Intel Mac, or Power PC?
<<<If I don't default>>>
Say that again and use different words.
Howard Brazee
Post by Howard Brazee » Fri Mar 06, 2009 11:34 pm
I could not find
/Users/HBrazee/Library/Application Support/Audacity
I could not find libmp3lame.dylib.
The Lame libraries that I installed are named: Lame Library v3.98.2 for Audacity.
When I run Lame Library v3.98.2 for Audacity.pkg it first asks me to select a volume, I select "Macintosh HD".
It tells me "You have chosen to install this software in the folder “lib” on the volume “Macintosh HD”."
If I hit (Choose Folder...) to find out where it is installing it (by default), it shows a default finder (without the path which I have set up for my regular finder) of libaudacity. I see a bunch of files which includes the one I can't find above. I hit the [|] button to try to find where I am, but that shows only the audacity directory here. I opened terminal and tried to find lib in the root. No luck.
I continued, it installed, but I have no idea where. Finder won't find the file, spotlight won't find the file.
Howard Brazee
Post by Howard Brazee » Sat Mar 07, 2009 11:38 pm
I decided to go on - I'll keep looking for my lib directory to clean up later, but for now I copied libmp3lame.dylib to a directory I know about.
When I ran Audacity, it looked for Only LameLib, which had this file grayed out. Then I enabled all files, and selected libmp3lame.dylib, and tried to open it. Audacity could not open MP3 encoding library.
Post by kozikowski » Sun Mar 08, 2009 12:03 am
I think the system administrators Did Something to make the lame process much easier and I'm not sure I like very much what they did.
