[SOLVED] How to extract multiple segments from audio file?
Shohreh
Re: [SOLVED] How to extract multiple segments from audio fil
Post by Shohreh » Mon Dec 28, 2015 8:28 pm
Good to know.
Upgraded to 2.1.1, re-opened the project, selected the section where the two parts join, hit Effect, applied Crossfade Clips: Worked like a charm.
Thank you.
Reason: Topic solved and locked
