Play at speed still doesn't work by keyboard.
It assign the key combination, but no response.
Will be fixed this bug?
By the way! Audacity : win-r1d137db-2.1.2-alpha-23-dec-15
Latest Audacity alpha BUG
- Quality Assurance
Re: Latest Audacity alpha BUG
Works fine for me on Windows 10, setting F9 as the key.pety wrote:Play at speed still doesn't work by keyboard.
It assign the key combination, but no response. win-r1d137db-2.1.2-alpha-23-dec-15
There should be no reason for it to be different on other Windows versions.
If you still think it does not work, please give exact steps to reproduce the problem including the key you assign. Are you using a non-English keyboard?
In Windows 7 doesn't work.
We can't fix something that's not broken. You should tell us exactly what you were doing when it failed.give exact steps to reproduce the problem
