can audicity do this...
benbernie
Post by benbernie » Wed Dec 23, 2015 1:24 am
hi
I want to change a music file from records from a wave file to an mp3 file..can audacity do that?
lenny
DVDdoug
Forum Crew
Re: can audicity do this...
Post by DVDdoug » Wed Dec 23, 2015 1:45 am
Yes, but you'll need to download the optional LAME MP3 encoder.
If you already have WAV files and you want to make an MP3, try TAudioConverter or search for a "WAV to MP3" converter. (An MP3 encoder or MP3 converter will be easier to use than an audio editor like Audacity.)
benbernie
Post by benbernie » Wed Dec 23, 2015 2:14 am
Thanks
