Please state:
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade (see
https://www.audacityteam.org/download/).
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
fiuuuu
Post
by fiuuuu » Thu Dec 17, 2015 10:28 pm
I am running Audacity 2.0.5 (downloaded from repositories) on Linux Mint 17.2 (Linux version 3.16.0-38-generic (
[email protected]) (gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1) ) #52~14.04.1-Ubuntu)
I have just tried to import Raw Data and look at its spectrum but Audacity crashed with a segmentation fault. No error messages are generated by Audacity.
How to reproduce:
- Launch Audacity;
- File → Import → Raw Data…;
- Choose the attached file “BUG CAUSING VERY DANGEROUS NEVER LOOK AT THE SPECTRUM BLYAD”;
- Choose the following options:
- Encoding: 64 bit float;
- Byte order: Big-endian;
- Channels: 1 Channel;
- Start offset: 0 bytes;
- Amount to import: 100 %;
- Sample rate: 44100 Hz;
- Try to look at the spectrogram.
- Segmentation fault!
You can see the output in the attached files.
- BUG CAUSING VERY DANGEROUS NEVER LOOK AT THE SPECTRUM BLYAD.zip
- This needs no comment
- (168.33 KiB) Downloaded 39 times
- audacity_err and audacity_out.zip
- (1.07 KiB) Downloaded 38 times
- Site Admin
Post
by steve » Fri Dec 18, 2015 1:11 am
I'm using Audacity 2.1.2 rc1 on Debian stable with XFCE desktop.
No segmentation fault, no crash, but the imported file is garbage with those settings.
Import with the detected settings:
- Byte order: Little-endian;
- Channels: 2 Channels (stereo);
and I get a stereo track with an 880 Hz sine wave.
