what is the highest sampling rate
This section is now closed
jonny
Post by jonny » Thu Mar 05, 2009 6:32 am
what is the highest sampling rate that can be set with the latest Mac version of audacity
44.1, 48, and 96 kHz
Masenberg talks about using some software and sampling at 300kHz .
Re: what is the highest sampling rate
Post by kozikowski » Thu Mar 05, 2009 6:23 pm
Without actually answering you, I can tell you you're in the wrong Audacity. All the advanced features are in 1.3.x. Audacity 1.2 was designed and produced just after The Reformation in Europe and it's pretty basic.
Further, even if the software does support it, the hardware has to do it, too. So it's a hand-holding operation.
Whenever somebody tries to do something like this, they do run into a few interesting problems. There are radio stations just above the audio band (25000Hz) and you suddenly are able to record them all. You need to have audio cables that not only shield for audio, but for radio interference as well. Any amateur radio operator will tell you that's a whole different world.
Also, as a side issue, the noise level goes up with bandpass, so even though you have frequency response that's flat out beyond where dogs can hear, the noise will kill you long before that sound channel becomes useful.
Then there's the drive space. You have lots, I hope. When you get to extreme services like this, you quickly peel off the ability of MP3 to compress it without damage.
What are you trying to achieve?
jonny
Post by jonny » Thu Mar 05, 2009 7:29 pm
I was just curious.
I do have the current version and did not realize that this forum was relative to a specific version.
I think the last time I used it was 1.3.3.
I do not have access to those high end A to D converters anyway.
I would assume that they were using the converters that are manufactured in Seattle and I think they are over $12k each.
they are usually rented as they are so expensive.
There is also a new system where one would have racks with 48 200gig hard drives and this is a new live recording to hard drive system. At any rate i am well aware of the storage space issue and A/D converters.
Like I say I was just curious about the Audacity max sampling rate.
96 or double that or something.
Post by steve » Fri Mar 06, 2009 1:48 am
Audacity can handle 192000Hz - probably more, but it becomes pretty irrelevant for audio recording.
jonny
Post by jonny » Fri Mar 06, 2009 3:34 am
that's what is next.
That is what works well for DVD's.
Al most all CD's sound pretty bad not to mention MP3's which sound terrible.
George Massenberg is doing stuff at 300,000 and that sounds closer to analog than anything so far
to each his own
on a good pair of goo speakers, monitors, or even good headsets you should be able to hear the difference pretty easily between 44.1k and 192k....big difference
It is about to double again especially when DVD2 and DVD 3 come out.
Of course it does not matter on earbuds or junk boomboxes
Thank you for the answer that it exactly what I was asking.
I have talked to engineers that like Audacity over protools
