Audacity & JACK: quest for the ultimate configuration
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Brendo613
Post by Brendo613 » Wed Mar 04, 2009 11:05 pm
Since upgrading to 1.3.5, I've had to start using JACK to avoid terrible, terrible skipping while recording. There is a large visual lag upon zooming in, or following the cursor, which is a nuisance ... anyone know the cause of this? More troubling, obviously, is the record quality, so I've set out to remedy this by configuring JACK.
I tried many different settings, and am now at a 232ms latency rating. Running Ubuntu, I recorded audio into the conputer as a stereo mix from a tape sent into a USB mixer. I recorded for a total of 90 minutes, and had the system playing back the audio as it was recording it. Also, I was running Baobab, a disk usage analyzer, which draws a visual representation of disk usage, a system intensive scanning process. I had no xruns during this test, a test which I designed to attempt a simulation of the system's most stressed state, while striving for clean recording.
While the test worked, I had a jam the other night, and encountered 2 xruns over the span of 1 1/2 hours. I was shocked! Why, why, WHY? Audacity and JACK were the only things running. Maybe my battery was charging (it's a laptop), affecting something? That shouldn't be. And something else senseless, the xruns are reported as some ridiculous number, like "xrun occured of at least 192383402834.2439ms." That's gotta be a few days, or something ...
My question is: what scenario could possibly cause xruns to occur that wouldn't have occured during the resource-intensive test?
Re: Audacity & JACK: quest for the ultimate configuration
Post by steve » Fri Mar 06, 2009 2:55 am
Brendo613 wrote:what scenario could possibly cause xruns to occur that wouldn't have occured during the resource-intensive test?
Update manager?
Brendo613
Post by Brendo613 » Fri Mar 06, 2009 10:27 pm
I guess it could be, but I did manage a successfully clean recording last night, 1.5+ hours. I set things a little different: 512 frames/period, 32 periods/buffer. Overall 372ms latency.
