I have just bought a Netbook on which I would like to load Audacity without having to go online. Is it possible to use my present PC to download Audacity to disc and then load it onto my new Netbook?
Ed
Audacity to CD
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
allencmcbride
Re: Audacity to CD
I don't see why not; just go to the download page (http://audacityteam.org/download/), download the appropriate package for your netbook, copy it to your netbook, and then open it or run it from there. They're small files; you could just use a USB drive instead of a CD if you want. --Allen
Re: Audacity to CD
<<<I have just bought a Netbook on which I would like to load Audacity without having to go online.>>>
You have a new NetBook which has very limited use without going on the net...and you're not putting it on the net.
Did I get that? I'm just reading this back to you.
Re: Audacity to CD
Yes, that's right. I got the Netbook mainly because of its small size and it does perfectly for what I want (copying practice songs for my banjo practice when I am travelling in my camper) at the moment and dont yet need to go online which I probably will do eventually.
I have now copied Audacity from my main pc and have it on my netbook OK.
Cheers
Ed
Cheers
Ed
