Batch record with Audacity? Multiple prompts !
This section is now closed
DJRobi
Post by DJRobi » Tue Mar 03, 2009 10:05 pm
I am a voice over artist and narrator with a telephony gig. I am trying to find out if Audacity can import a script and help me to "batch-record" for lack of a better term.
I have used software - for a PC - that imported the script and even named each individual prompt recording - as long as the script is in correct format. I am now trying to find something similar for the Mac user.
Thanks in advance for any suggestions.
Re: Batch record with Audacity? Multiple prompts !
Post by kozikowski » Tue Mar 03, 2009 10:26 pm
And the PC software is called?
DJRobi
Post by DJRobi » Tue Mar 03, 2009 10:37 pm
I can't recall ...but I'm using a Mac now.
I used it a few years back on a PC that I no longer own.
Are you aware of anything like that for the Mac?
Post by kozikowski » Tue Mar 03, 2009 10:55 pm
No, but maybe somebody else will jump in. Not knowing what the original software was puts a serious crimp in the search--especially special purpose software like that.
DJRobi
Post by DJRobi » Wed Mar 04, 2009 6:40 pm
Thanks,
I have now found something for Mac called "VoxOver" and it imports scripts.
I'd love to see a batch recording feature for Audacity too.
