New installation, cannot preset Mono recording [SOLVED]
Emerogork
Post by Emerogork » Thu Dec 03, 2015 11:13 am
I will be recording in Mono for all instances of Audacity. How do I set this as default so that I do not have to make changes every time I start the program?
Re: New installation but cannot preset for Mono recording on
Post by Gale Andrews » Thu Dec 03, 2015 11:56 am
Device Toolbar can be used to set Recording Channels to mono. This applies whatever device you use. The setting is saved per user.
Are you saying that setting mono there does not stick? If so please give us the necessary information from the pink panel at the top of the page. Give us the make and model number of the recording device.
Emerogork
Re: New installation, cannot preset Mono recording [SOLVED]
Post by Emerogork » Thu Dec 03, 2015 2:53 pm
Gale Andrews wrote:Device Toolbar can be used to set Recording Channels to mono. This applies whatever device you use. The setting is saved per user.
Oop. my bad,......
I forgot about the option in the tool bar. I was looking for a pull down menu option.
Life is good again.
