How do I create a rewind tape effect?
Vivii
Post by Vivii » Thu Nov 26, 2015 1:20 pm
Hi guys,
I need to create a rewind effect, as if you're rewinding an old video or tape or something. I get that I have to reverse the audio and increase the speed, but with rewinds, the speed increases continually right? How do I do that? And do I have to add some sort of background sound too? I would greatly appreciate the help!
waxcylinder
Re: How do I create a rewind tape effect?
Post by waxcylinder » Thu Nov 26, 2015 2:24 pm
reverse the audi with Effect > Reverse - the play with the Effect > Sliding Time Scale / Pitch Shift
See this page in teh Manual: http://manual.audacityteam.org/o/man/sl ... shift.html
Try leaving the Initial Tempo Change at zero and try increased vlaues for Final Tempo Change
And similar with the pitch shift (Initial chage 0 and up the final) as you would want the pitch to go up too.
You will need to experiment to get suitable values.
I just experimented with a 25 second clip and used 0 => 350 % and 0 => 6 semitones - quite effective :geek:
Vivii
Post by Vivii » Thu Nov 26, 2015 3:30 pm
You are my hero. Thanks so much!
Post by steve » Fri Nov 27, 2015 11:28 am
waxcylinder wrote:the play with the Effect > Sliding Time Scale / Pitch Shift
Alternatively you can use a "Time Track" http://manual.audacityteam.org/o/man/time_tracks.html
This was produced by reversing a section, then using a Time Track to change the speed:
timetrack-effect.ogg
(79.35 KiB) Downloaded 131 times
Robert J. H.
Post by Robert J. H. » Fri Nov 27, 2015 1:02 pm
Oh good old times.
That's like a sentimental journey. I see myself sitting there and winding up a tape with a pencil...
