mix and render to new track
suttlemyre
when you use this feature, Lets say I have 9 traks and add just to my likings. Mix and render to new track, does it change my settings.
Re: mix and render to new trak
Probably not. What "settings"?does it change my settings.
suttlemyre
volume settings of different tracks
suttlemyre
Re: mix and render to new track
what does render do
- Quality Assurance
See http://manual.audacityteam.org/o/man/tr ... u.html#mix. Yes it will apply for example the gain or pan setting on the track to the waveform, and so the gain or pan slider will return to centre.
suttlemyre
Thank you Gale.
