question about change timescale change to 432hz
Re: question about change timescale change to 432hz
Post by steve » Sun Dec 27, 2015 11:00 am
movebetter wrote: they are about 2% longer instead of 2 % shorter
Longer is correct. (1.818% longer)
movebetter
Operating System: Windows 7
Post by movebetter » Mon Dec 28, 2015 12:37 am
i am trying to go from 440hz to 432hz and i am using -1.818. this has been working for a few months now but now makes the tracks longer instead of shorter. see attached. thanks,
432 convert.png (335.55 KiB) Viewed 849 times
Reason: Put images inline so they don't break the board layout
Post by steve » Mon Dec 28, 2015 12:43 am
movebetter wrote:i am trying to go from 440hz to 432hz and i am using -1.818. this has been working for a few months now but now makes the tracks longer instead of shorter. see attached. thanks,
Please see this post: http://forum.audacityteam.org/viewtopic ... 75#p294275
movebetter
Post by movebetter » Mon Dec 28, 2015 1:20 am
i dont understand
Post by Gale Andrews » Mon Dec 28, 2015 2:15 am
You have the choice to use Change Speed and accept the track becomes longer, or Change Pitch, which means the track stays more or less the same length.
movebetter
Post by movebetter » Mon Dec 28, 2015 6:49 pm
ok, i see, supposed to be longer. sorry and thank you..
