export to burn cd
This section is now closed
enrico sartini
export to burn cd
Post by enrico sartini » Sun Mar 01, 2009 11:17 pm
i have a problem: i have 1h. of mixed music (1h togheter) and i try to make more tracks, can make whit audacity?..... :?
Re: export to burn cd
Post by kozikowski » Mon Mar 02, 2009 2:34 am
Yes. Put a Label at the beginning of each song. Apple-B.
Then File > Export Multiple > WAV. Audacity will make many songs that you can put in iTunes.
Create a Playlist in iTunes and move your songs to that playlist. Then burn a CD.
Let iTunes tell you when to put the CD inside. Do not put the CD inside too soon.
