How does one reposition the cursor w/o changing anything?
Help for Audacity on macOS.
David B
Post by David B » Sat Nov 07, 2015 5:20 pm
I have a rough trim of my audio. I want to stop the cursor and have it remain where it is in order to see if this will be my new start point. Or, I want to place the cursor where I believe my start point will be and play from there. I do not want it to change anything that I already have done. Thanks in advance.
Re: How does one reposition the cursor w/o changing anything
Post by kozikowski » Sat Nov 07, 2015 6:08 pm
You can simulate that with Labels and Select.
Put a label at the new potential start point.
http://manual.audacityteam.org/o/man/label_tracks.html
Labels are sticky and a drag-select will try to stick to it. Play will follow the selection, repeatedly if needed.
You can delete, move and manage labels.
waxcylinder
Post by waxcylinder » Sun Nov 08, 2015 1:25 pm
David B wrote: I want to stop the cursor and have it remain where it is ...
The shortcut Shift+A will stop playback (or recording) and place the cursor at that point (a bit like how tape decks work)
Personally I find the compound gesture awkward so I changed the shortcut to KEYPAD_INS (I just have to remember to ensure tha Numlock is off).
