Audacity crash
pety
Audacity crash
Post by pety » Thu Nov 05, 2015 9:21 am
I tried tu use Amplio2 plugin and Audacity crashed.
Operating System: windows 10.
Audacity_dbgrpt-7436-20151105T111708.zip
Debugg report from Audacity alpha - 4 Oct
(147.73 KiB) Downloaded 13 times
pety
Re: Audacity crash
Post by pety » Thu Nov 05, 2015 9:46 am
It is 4 NOV alpha. Sory for mistake.
Re: Audacity crash
Post by Gale Andrews » Thu Nov 05, 2015 9:27 pm
Thanks for the report. I found it prone to crash even when trying to enable it. It seems safe if you open it without audio playing and then press Apply, without pressing Play in the effect. I added a bug report http://bugzilla.audacityteam.org/show_bug.cgi?id=1257.
