Output levels distorted after restarting audacity
Please state:
Please state:
BlueRain508
Hey everyone, I'm new here so I could be making a newb error lol. Everything had been going relatively smoothly for a few weeks until I restarted my computer and audacity one day only to find that everything that I recorded sounded really distorted. I noticed if I moved the bass all the way down and the trebel all the way up, it would almost sort of fix the disortion, but it would throw the quality of the track completely off. I tried adjusting the sound controls in alsamixer, no luck there. If I move the gain down, it helps somewhat, but it just makes it sound too quiet, and doesn't take the disortion away completely anyway. Even if I open a new project I still get the same distortion. Do any of you have any ideas why this would happen all of a sudden and what I can do about it? I'm using xfce4 if that helps at all.
Re: Output levels distorted after restarting audacity
Does your computer sound system use PulseAudio?
Which Linux distribution?BlueRain508 wrote:I'm using xfce4
BlueRain508
Honestly I'm not sure. Is there a way to find out? I'm completely new at this whole Linux thing. I really only downloaded Linux so I could use audacity since it's not compatible with Chromebook.steve wrote:Does your computer sound system use PulseAudio?
Ubuntu I believe.steve wrote:Which Linux distribution?
So you're running some version of Linux on a Chromebook with XFCE desktop?
Could you enter this command into a terminal window, and tell us what the output is:
and then
then open Audacity and look in "Help > About Audacity" for the full version number of Audacity.
Code: Select all
lsb_release -a
Code: Select all
pulseaudio --version9/10 questions are answered in the FREQUENTLY ASKED QUESTIONS (FAQ)
BlueRain508
Yes.steve wrote:So you're running some version of Linux on a Chromebook with XFCE desktop?
lsb_release: error: No arguments are permittedsteve wrote:Could you enter this command into a terminal window, and tell us what the output is:Code: Select all
lsb_release -a
(precise)[email protected]:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 12.04.5 LTS
Release: 12.04
Codename: precise
bash: pulseaudio: command not foundsteve wrote:and thenCode: Select all
Audacity 2.1.1-alpha-Apr 8 2015steve wrote:then open Audacity and look in "Help > About Audacity" for the full version number of Audacity.
Please note that I have never tried running Linux on a Chromebook.
I am trying to work out how the audio system is configured on your machine so that I can try to help.
In Audacity, select "Help > Audio Device Info".
Copy and paste the full output into your reply.
BlueRain508
steve wrote:Please note that I have never tried running Linux on a Chromebook.
Thank you, I appreciate it!
steve wrote:In Audacity, select "Help > Audio Device Info".
Code: Select all
Default recording device number: 1
Default playback device number: 1
Device ID: 0
Device name: cras
Host name: ALSA
Recording channels: 2
Playback channels: 2
Low Recording Latency: 0.011610
Low Playback Latency: 0.011610
High Recording Latency: 0.046440
High Playback Latency: 0.046440
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
Device ID: 1
Device name: default
Host name: ALSA
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
Selected recording device: 1 - default
Selected playback device: 1 - default
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
Unable to open Portmixer
Reason: wrapped audio device info in code tags for readability
It appears that Chromebooks have a unique audio device setup. https://www.chromium.org/chromium-os/ch ... dio-server
What exactly are you trying to record?
Are you able to adjust the recording level so that you get a signal in Audacity that is about half the track height? If so, please make a short test recording and export a few seconds in WAV format and attach the file to your reply (see here for detailed instructions: http://forum.audacityteam.org/viewtopic ... 49&t=72887)
BlueRain508
Haha yeah, Chromebooks are definitely a pain.steve wrote:It appears that Chromebooks have a unique audio device setup. https://www.chromium.org/chromium-os/ch ... dio-server
I'm trying to record vocals on top of a beat that I imported.steve wrote:What exactly are you trying to record?
Ok here it is. I think I did it correctly.steve wrote:Are you able to adjust the recording level so that you get a signal in Audacity that is about half the track height? If so, please make a short test recording and export a few seconds in WAV format and attach the file to your reply (see here for detailed instructions: http://forum.audacityteam.org/viewtopic ... 49&t=72887)
- Attachments
- ForumSample.wav
- (117.04 KiB) Downloaded 26 times
Here's the problem. See how the waveform has a "notch" in it where it briefly goes to the centre line. I've highlighted one, and there is another one visible a little earlier.
Those notches should not be there. The strange thing is that they occur at exact intervals of 128 samples.
I doubt that this is an Audacity problem. It looks more like a problem with the audio device drivers.
Try running this command in a terminal window. It will record 6 seconds of audio (starting when you press "Enter") from the default device (should be your mic). By default it will save the file to your home folder:
If for some reason it does not return to the normal terminal prompt after 6 seconds, press Ctrl+C to abort.
Try that and see if the "distortion" problem occurs there.
Code: Select all
arecord -d 6 -f S16_LE -t wav -c 1 test.wavTry that and see if the "distortion" problem occurs there.
