Stream is active ... Unable to gather information ...?
Emerogork
Post by Emerogork » Sat Oct 24, 2015 4:33 pm
Win 7.1, Audacity v 2.06
This was running many moons ago but now it shows the incoming signal in the meters and in the audio track. However, it shoes only 6 seconds of wave form then the line is flattened and the next 6 seconds show. Time is passing on the track but even if I stop the "recording" the track is flat lined.
Any fix for this?
Re: Stream is active ... Unable to gather information ...?
Post by kozikowski » Sat Oct 24, 2015 4:44 pm
If you're recording music and the song starts adjusting its own volume, that could be Windows Enhanced Services.
http://manual.audacityteam.org/o/man/fa ... hancements
Emerogork
Post by Emerogork » Sat Oct 24, 2015 4:55 pm
Nothing is recording, the audio level is strong all the time.
The meter is always indicating the presence of the signal.
Audio track shows up to 6 seconds of signal then it goes flat.
Lather Rinse Repeat....
Post by kozikowski » Sat Oct 24, 2015 6:33 pm
You mean the blue waves go flat? You can get that if Audacity runs out of room to store the sound. Are you running out of drive space?
Audacity 2.06 is a fake version. There is an Audacity 2.0.6.
You can upgrade to the latest Audacity 2.1.1 here.
http://audacityteam.org/download/windows
Emerogork
Post by Emerogork » Sat Oct 24, 2015 6:42 pm
2.0.6, my bad....
I have over 177G free on the drive reported when I hit "Save As" however, I do see that A is not reporting hours left of recording time.
I will upgrade to 2.1.1 and report back. Maybe just a reinstall will do it.
Post by kozikowski » Sat Oct 24, 2015 6:54 pm
You could have crossed permissions, too. 177GB, but Audacity doesn't have permission to wrote to any of it.
Post by Gale Andrews » Sat Oct 24, 2015 9:08 pm
Look at Edit > Preferences... then the "Directories" section. Assuming you have not saved a project, that is where Audacity writes to. That directory needs write permissions and the drive that directory is on needs the space.
Emerogork
Post by Emerogork » Sat Oct 24, 2015 10:16 pm
Yep, I found it about 10 minutes before I read your post. It was a change in the Temp folder.
Seems to me that an error should have popped up, no?
Oh well, it is still a great program.
Post by Gale Andrews » Sun Oct 25, 2015 1:11 am
Emerogork wrote:Yep, I found it about 10 minutes before I read your post. It was a change in the Temp folder.
Yes, and we have that on our radar, but throwing error message boxes from errors that appear in the log is harder than it might seem to be: http://bugzilla.audacityteam.org/show_bug.cgi?id=437.
