pitch shift
suttlemyre
pitch shift
Post by suttlemyre » Thu Oct 22, 2015 12:33 am
What settings would you use to add a bass line to a song in C/G/F from a six string ,electric to sound super deep. no tempo change just a deeper bass sound on another track with a few bass runs. Every thing I do makes it sound weird.
Trebor
Re: pitch shift
Post by Trebor » Thu Oct 22, 2015 2:06 am
suttlemyre wrote:What settings would you use to add a bass line to a song in C/G/F from a six string ,electric to sound super deep. no tempo change just a deeper bass sound on another track with a few bass runs. Every thing I do makes it sound weird.
Audacity has two different pitch-shift effects , each adds weird artefacts ...
"Change Pitch" & "Sliding time scale/pitch shift" the latter is more musical.
"-50%" drops the pitch by an octave.
Re: pitch shift
Post by steve » Thu Oct 22, 2015 10:50 am
+1 for Trebor's answer.
suttlemyre
Re: pitch shift
Post by suttlemyre » Fri Oct 23, 2015 12:40 am
thanks guys, what I was looking for
suttlemyre
Re: pitch shift
Post by suttlemyre » Sat Oct 31, 2015 1:41 am
ok still can not get the full octave lower with a true tone. I want no tempo change just to add a bass string here and there and try to sound like a super deep bass, do I leave settings at preset then only lower the final pitch or what, I can not figure this out. I have most of this program figured out and get super clean recordings now and love it. I probably just need to buy a bass guitar.
Trebor
Re: pitch shift
Post by Trebor » Sat Oct 31, 2015 2:10 am
suttlemyre wrote:ok still can not get the full octave lower with a true tone.
Shifting the pitch down in Audacity will only be an approximation of a true bass guitar : inevitably the processing will make it sound a little computery.
suttlemyre wrote:I probably just need to buy a bass guitar.
Midi sequencing software can provide you with the sound of any instument.
https://en.wikipedia.org/wiki/Compariso ... sequencers
Some midi software will translate the note you play on the guitar into another instrument in real-time ...
https://www.youtube.com/watch?v=JTjoy_CQn1g
[ Audacity does not speak midi ]
Re: pitch shift
Post by kozikowski » Sat Oct 31, 2015 2:20 am
It's the same problem as trying to shift a human voice. All the sounds your face makes do not shift.
The touch, the strike, the release and in some cases the resonance of the string shift very little between instruments. If you try it, it will sound other-worldly (or computer-y) You can shift the musical note without shifting everything else, but you have to do it note at a time.
So you're right. Record an actual bass.
suttlemyre
Re: pitch shift
Post by suttlemyre » Sun Nov 01, 2015 9:16 pm
audacity demo.mp3
(284.54 KiB) Downloaded 32 times
haven't had the extra cash to buy the bass I prefer,but borrowed a Radio Shack organ to fill in the dead spots. have never played organ before, but I may dig it. heres a little sample
Trebor
Re: pitch shift
Post by Trebor » Mon Nov 02, 2015 1:59 am
This is what pitch-shifting guitar down by an octave sounds like using Audacity's "sliding Time Scale/Pitch Shift".
original , -1 octave , combo.wav
(1014.3 KiB) Downloaded 41 times
sliding Time Scale- Pitch Shift settings.png (9.31 KiB) Viewed 544 times
suttlemyre wrote:audacity demo.mp3
IMO that needs dynamic range compression, e g. ...
audacity demo, Before_After compression +.mp3
(1.33 MiB) Downloaded 16 times
