Hey guys,
I did a lot of reading and even called Roland before I posted this:
I'm using a ROLAND QUAD CAPTURE interface. It has two channels: "INPUT 1 L" and "INPUT 2 R"
For some reason, Audacity is recording both of the mics on to one mono track. It is not recognizing each track to be separate...
I want to record two individual, mono, tracks (mics) simultaneously.
I just have to figure out how to get audacity to recognize the two tracks coming out of the quad capture as 2 individual mono tracks...
Help?
Thanks
Audacity not recognizing 2 mics??...
- Quality Assurance
Re: Audacity not recognizing 2 mics??...
Audacity cannot do that yet. Set Audacity in Device Toolbar to record in stereo, then use the Audio Track Dropdown Menu to "Split Stereo to Mono".T.M.A. wrote:Hey guys,
Awesome. I think that is exactly what I'm looking for...
Thank you...
Thank you...
