I'm running Audacity 2.0.6 on a Mac Air upgraded to El Capitan (10.11).
I get the error message to properly configure ffmpeg. Found lots of advice here on how to do that. I drill down to libavformat.tv. I select it, then click OK, OK. That should do it, I understand. But I keep getting the error message.
I have two clues that might be of help. When I browse for the right location, Finder suggests the "Dynamic Libraries (*.dylib) format. That works as far as Download/libav-11.3/libavformat. In libavformat, though, all the files are greyed out. I have to change the Format dropdown from Dynamic Libraries to All Files to make them all clickable.
All the files there have the turned-corner paper icon. All the icons eexcept libavformat.v have writing on them. The libavformat.v icon is blank.
Any idea what I'm up against here? This just goes on and on. I've installed with Audacity on, and Audacity off. I'll found and deleted every ffmpeg file or page on the Mac, emptied the trash, and started fresh. I restarted the Mac right after the install to see if that helps. Nothing. Nada.
I'd appreciate any advice. I have only the most basic knowledge of audio processing and the deep dark workings of software, so the plainer you can make your advice, the more likely I'll be able to us it!
Thanks very much.
