how could i loop this and make a practice track
suttlemyre
Post by suttlemyre » Fri Oct 16, 2015 12:15 am
TheTemptations-SilentNight_KeyOfC_.mp3
(234.82 KiB) Downloaded 39 times
Re: how could i loop this and make a practice track
Post by kozikowski » Fri Oct 16, 2015 4:38 am
Probably. I would be slicing off a lot of before and after to get the major downbeats to line up, but I think you can do it. For example, somewhere around 5 should loop with somewhere around 27.
http://manual.audacityteam.org/o/man/tu ... oping.html
Since this doesn't have to be surgically accurate, I got one to work by just duplicating the track and push the bottom one to the right with the Time Shift Tool (two sideways black arrows) until a major drum hit lines up (attach).
Screen Shot 2015-10-15 at 21.33.20.png (120.53 KiB) Viewed 257 times
TheTemptationsLoop.mp3
(818.04 KiB) Downloaded 21 times
Trebor
Post by Trebor » Fri Oct 16, 2015 4:44 am
If you look at the audio in spectrogram view you'll see repeating patterns which will suggest looping points.
can't spot the join [ PseudoStereo +EQed].flac
This is loopable
(1.95 MiB) Downloaded 23 times
