Nyquist plug-in problems
This section is now closed
jaredistheman
Post by jaredistheman » Thu Feb 26, 2009 5:13 am
I'm having trouble installing a nyquist plug-in. Where do i need to put it to get it to show up in the "effects" tab? I have it under MAC hdd>Library>Audio>Plug-ins but it's not showing up under the effects menu. Thanks for any help!
allencmcbride
Re: Nyquist plug-in problems
Post by allencmcbride » Thu Feb 26, 2009 5:18 am
It goes in the "plug-ins" folder (as opposed to the "nyquist" folder, which you might expect). --Allen
allencmcbride
Post by allencmcbride » Thu Feb 26, 2009 5:20 am
Oops, I didn't see the last half of your question. It goes in Applications/Audacity/plug-ins, not in the Library/Audio/Plug-ins. --Allen
jaredistheman
Post by jaredistheman » Thu Feb 26, 2009 3:50 pm
Well i mean as you know on alot of mac programs there are just icons. So i don't know how to get to the plug-in's folder inside of audacity. I appreciate your help though!
allencmcbride
Post by allencmcbride » Thu Feb 26, 2009 3:56 pm
When you downloaded the Audacity package and opened it, you should have seen several files and folders inside, including Audacity.app. For a lot of applications, you just copy the .app file to your Applications folder. But for Audacity, you should create a folder inside your Applications folder called "Audacity" and then copy everything that was in the package into this folder. One of these things will be the "plug-ins" folder I'm talking about. --Allen
jaredistheman
Post by jaredistheman » Thu Feb 26, 2009 4:01 pm
Oh okay sweet! Thanks for all your help and lighting quick replies!
allencmcbride
Post by allencmcbride » Thu Feb 26, 2009 4:12 pm
No problem. Good luck. --Allen
