Hi Koz,
I've resorted to using a PC laptop to record and then edit on my Mac unit this is sorted out with Mac. I got all done fortunately. Thanks for all your support and I'm trusting Mac will squash this bug asap!
All the best,
Bonita
Mac OS X 10.11 El Capitan & Audacity not working
Re: Mac OS X 10.11 El Capitan & Audacity not working
Hi Gale,
Only saw your reply now - thanks so much for that. I'll just keep waiting and see what Apple and Audacity come up with to sort it out...
Thanks a mil!
Bonita
Thanks a mil!
Bonita
The 10.11.1 update for El Capitan is available in the app store:
https://support.apple.com/en-us/HT205360
No news about USB updates. But those are probably not worth mentioning?
Thank you, I've downloaded it already and it's still not working
But thanks for the update!
