Increase sound volume
cowboy
Post by cowboy » Fri Oct 09, 2015 2:30 pm
Not sure if this is the right section or not ??
but I wanted to see if there was a way to input a mp3 file into Audacity and while there editing it or whatever, tweak something so that the saved version would output more volume ?
Here is the issue, I have mp3 files, that have a relatively low volume (when I play them in the car for instance I have to crank the vol. up all the way)
so I'm wondering if there is a feature or property I can change to increase the vol level when I'm done editing and saving the file.
p.s. not sure that this would matter, but these aren't music files, just speech.
Re: Increase sound volume
Post by steve » Fri Oct 09, 2015 3:02 pm
The "Amplify" effect with default settings will increase the level as much as possible without "clipping" (distorting) the sound. If you need more amplification than that it is necessary to "compress the dynamics", either using a "compressor" effect or a "limiter" effect. I'd suggest that you just try amplifying before attempting anything more complex.
If you require further help, please tell us which version of Audacity you are using (look in "Help menu > About Audacity", and what operating system you are using. We can then move this topic to the appropriate Windows/Mac/Linux board and give more detailed help.
cowboy
Post by cowboy » Fri Oct 09, 2015 3:35 pm
Thanks, I will try the amplify selection next chance I get.
I'm using ver 2.0.5 with Windows 7
As a followup question,
since I sometimes have many of these to do, is there a way to do this via code, script file, program or whatever,
so as to be able to do many at once. In other words, change that parameter via a script.
Post by steve » Fri Oct 09, 2015 4:27 pm
Topic moved to Windows forum.
cowboy wrote:since I sometimes have many of these to do, is there a way to do this via code, script file, program or whatever,
Let's see if "Amplify" does what you want. If it does, then yes it's possible to "batch process", but you will need to use "Normalize" rather than "Amplify". Let us know how you get on with Amplify and we'll take it from there.
cowboy
Post by cowboy » Sat Oct 10, 2015 2:30 pm
Hello,
I have tried the amplify , seems easy enough, 1st I did a ctr-A to select the track, then went into amplify, slid the bar over and did a preview, didn't seem to change the vol.
I tried a few there times, typed in a value, or just hit OK, but no change when I re play it ??
Post by steve » Sat Oct 10, 2015 2:41 pm
Try this:
1. Import a file that you know is quiet.
2. Select All
3, Open the Amplify effect - write down what the default settings are and tell us in your reply.
4. Apply the effect with the default settings.
Has the waveform become noticeably taller?
Does it sound any louder?
Post by Gale Andrews » Sat Oct 10, 2015 9:01 pm
cowboy wrote:I have mp3 files, that have a relatively low volume (when I play them in the car for instance I have to crank the vol. up all the way)
Just to add to this, although you probably don't mind for speech, you will lose quality by rewriting (saving) the MP3.
The only reason why Amplify on default setting (which maximises the volume) might not make the file sound loud enough would be if there were some stray loud noises or shouts in the file that are already as loud (or almost as loud) as can be. That is when you need to use a compressor to reduce the difference between loud and soft.
If Amplify and OK really does make the files louder, then you can do what you want quicker and without audio losses by using MP3 Gain.
cowboy
Post by cowboy » Sun Oct 11, 2015 1:57 pm
I ran as described by Steve,
the default in the amp window was 2.8 with the , with the "new peak amp" at 0.
The allow clipping box was unchecked, I hit OK
The waveform did become taller, but when I play it doesn't seem a whole lot louder, not noticeably.
p.s. I was going to show some pic/clips but apparently you can't do attachments here
Post by steve » Sun Oct 11, 2015 5:49 pm
cowboy wrote:I ran as described by Steve,
That means that the "peak amplitude" (the tallest part of the waveform) is 2.8 dB below the absolute maximum valid level for (normal) digital audio. The absolute maximum being 0 dB.
Note that it may just a single "spike" at -2.8 dB (2.8 dB below 0 dB).
To get the overall level louder, it is necessary to amplify the quieter parts without amplifying the highest peaks. This is where "compressors" and "limiters" come in.
Try the same experiment again, but after running the Amplify effect, run the Limiter effect (http://manual.audacityteam.org/o/man/limiter.html). Use the default settings except for the "Make up gain" - set "Apply makeup gain" to "Yes". That will give you an additional +3 dB to all but the highest peaks - not a huge amount, but in addition to the 2.8 dB from the Amplify effect, that may be enough.
Post by Gale Andrews » Sun Oct 11, 2015 6:31 pm
cowboy wrote:I was going to show some pic/clips but apparently you can't do attachments here
If you do ever need to attach images or audio files, please see http://forum.audacityteam.org/viewtopic ... 49&t=64936.
