The sample above should be Jefferson Airplane, with the clicking sound.
Host is MME. Is that ok?
Can someone tell me what the heck this is!?
HarryHogge
- Quality Assurance
Re: Can someone tell me what the heck this is!?
HarryHogge wrote:The sample above should be Jefferson Airplane, with the clicking sound.
How long is that clip, then we can identify it? Your link plays two different clips.
MME is most compatible, but not necessarily the best. I've explained the factors that come into play when choosing host, but choose the host that works best for you with your setup.HarryHogge wrote:Host is MME. Is that ok?
HarryHogge
- Quality Assurance
If it's the attached, I cannot hear clicks or dropouts, sorry, but my ears are late middle-aged. If that file is still a problem please state time points where the problems are.HarryHogge wrote:My bad. the one titled 'error', and it's 12 seconds.Gale Andrews wrote:
- Attachments
- error by 8 Diagram Pole Fighter.mp3
- (189.39 KiB) Downloaded 18 times
